To use a Pegasus M4 on a modern MAC, use the latest PegasusM4 driver. For Intel macOS, the driver is builtin. For M1/M2/M3 macOS use the DEXT driver v21.1.0-2
After installation, ensure to 'allow' the driver in System Settings on your Mac. For assistance, please refer to the Guide.
Managing a Pegasus M4 with a modern macOS
To manage a Pegasus M4 on a modern MAC, Use the latest Promise Utility, v4.06.0000.04
Updating firmware in a Pegasus M4
Prior to utilizing the Pegasus M4 with your Mac computer, it's crucial to complete the update procedure. Please be aware that the Pegasus M4 firmware file isn't intended for Mac use; instead, it's utilized by the Promise Utility to update the Pegasus M4 firmware.
Download and use the latest Pegasus M4 firmware v6.06.0000.45
To update the firmware using the latest Promise Utility:
1. From the Admin drop-down menu in the menu bar of the Promise Utility, choose Firmware Update.
2. Click on the padlock icon to unlock the menu, and type in the password for your computer when the prompt appears.
3. Click the Choose File button and locate the .img file you downloaded.
4. Click the Submit button.
5. In the Confirmation box, type the word “confirm” in the field provided and click the Confirm button.
6. The process will take several seconds to complete. Once the process has completed, it is necessary to restart the computer.Once the computer is powered on and booted up, you may continue to use the Pegasus M4.
To update the firmware using the latest Promise Utility Pro, refer to this KB article: https://kb.promise.com/thread/pegasus-m4-firmware-update-by-promise-utility-pro/
