Product: M-Class
Product Description: All iSCSI products
Platform: Independent
Firmware/Bios Version: SR2 and above
Additional Description: The procedure below applied to all of the M-Class products for clearing FRAM on the controller.
Solution: How to clear the FRAM within VTrak M-Class?
You always advise the customer to backup his/her data before proceed below:
Restart the VTrak; while the unit booting up
Press "Ctrl F" to get to IBLROM screen
Type "diag" and Enter to get to the System Hardware Diagnostic Tests
At the Menu use the list:
Select option 2: NVRAM Memory Test and Restore the default. Then, Enter
Select option 8: Test all NVRAM location (The test will run for about 2 second)
Select option 9: To Clear NVRAM
Select option 10: To restore NVRAM back to manufacture default
Select option 0: Again, to quit and back to IBLROM screen
Select option 0: To exit the System Hardware Diagnostic Test
Type "reset" to restart the VTrak and back to the login prompt.
