Installing the macOS Pegasus DEXT driver
  • 10K Views
  • Last Post 01 November 2024
Babatunde Akinkuolie posted this 01 November 2024
 Introduction
  • The DEXT driver does not require changing boot permissions, please leave boot permissions at the default, which is Full Security.
  • The Pegasus32 DEXT driver is compatible with all Pegasus models except the Pegasus Pro.
  • macOS first supported DEXT drivers in Big Sur (v11.0), however the Pegasus DEXT driver supports Monterey (v12.0) and above.
  • Do not try to install the both the KEXT and the DEXT, install only the DEXT with the process below.
 Note, this
Installation
First download the DEXT driver. Here is a link to the current DEXT driver.
This driver is from the Pegasus32 downloads page.
Currently the Pegasus32 downloads page is where to look for the latest DEXT.
The download is a disk image (dmg file). Double click to open it.
Double click on the installer package and the install will begin.
Enter your password.
Next, Apple requires that the user manually approve the driver as a security measure.
Select Open System Settings and the installer will take you to the correct place to Allow the driver.
Click Allow and the driver will load.
If you have the latest MacOS Sequoia, enable the extensions as it is a little different with previous OS versions. You can refer to the installation guide from here
  • Enable the Pegasus DEXT Driver Installer by entering your password again.
  • Click Done to complete the installation.
If the Pegasus is attached to the Mac, the Volume should mount in less than a minute.
 Final Cut...
The installer creates an app in the Applications folder.
The driver has already been installed, do not run this app now.
If you run the app when the driver is installed, it will uninstall the driver.
if you run the app when the driver uninstalled, it will install the driver.
If you delete the app it will uninstall the driver.
Run this app only when you want to uninstall the DEXT driver.
So generally, pay no attention to the app behind the Applications folder.
Confirming the Driver Installation
Use either of these methods to confirm successful installation:
  • Method #1: Pegasus DEXT Driver Installer
    • Go to Applications and double-click Pegasus DEXT Driver Installer.
    • If installed, you’ll see an "Uninstall" option in the pop-up window.
Method #2: Terminal Commands
  1. Open Terminal and enter: sudo -s . Input your password when prompted.
  2. Then, enter: systemextensionsctl list | grep pegasus
  3. Look for "activated enabled" in the output to confirm activation.
Note : If the screenshot output below says "activated waiting for user" after entering systemextensionsctl list | grep pegasus , This indicates that the Pegasus driver is installed but requires manual approval in your Mac security settings before it can function properly. Allow the driver and restart your Mac . After rebooting, run the following command again (systemextensionsctl list | grep pegasus) to confirm the driver status says "activated enabled
Following these steps will ensure your Pegasus Thunderbolt connection functions properly.
Troubleshooting Notes:
  • If the status still shows "activated waiting for user", repeat the steps and verify that the driver approval was successful.
  • Confirm the macOS version is compatible with the Pegasus driver.
  • Uninstall and Reinstall the driver if needed.
  • Contact Promise Technical Support for additional assistance for further assistance
  • Liked by
  • William Drakus
  • Nels Andersen
Close
