To connect the legacy Pegasus1 or Pegasus2 chassis to an M1/M2/M3/M4 Mac system, you must use the original Apple Thunderbolt 3 (USB-C) to Thunderbolt 2 Adapter.
Recommended Adapter:
Compatibility Notes:
  • Pegasus1 and Pegasus2 require this adapter for connection to modern Mac systems equipped with USB-C/Thunderbolt 3/4 ports.
  • Pegasus3 , Pegasus M4, and Pegasus32 do not require an adapter. These models natively support Thunderbolt 3/4 connections.
Important Setup Steps:
  1. Adapter Connection:
    • Plug the Thunderbolt 2 cable from the Pegasus1/Pegasus2 into the Apple Adapter.
    • Connect the USB-C end of the adapter into your Mac's Thunderbolt 3/4 port.
  2. Power On the Pegasus Unit.
  3. Check Connection:
    • Open Mac System Information → Thunderbolt section.
    • Confirm the Pegasus device is detected.
       4. Install the DEXT Driver (macOS Sequoia or Later) if you haven't done so
For any further issues or troubleshooting, contact Promise Technology Support or or visit the Promise Knowledge Base.
