Using the default configuration Pegasus R4i.
Example of performance numbers obtained from out-of-the-box Mac Pro 2019, and Pegasus R4i.
Test Software: Blackmagic Design, Disk Speed Test 3.2
Test Hardware: Mac Pro 2019 8 core Xeon, 32gb ECC DIMMs, 580x Module, Pegasus R4i 4xTB RAID 5 7200rpm 8TB (default config)
The performance numbers should be similar to what is exhibited below.
*Please note the numbers provided are ball park figures. Results will vary.
