Product: SNMP
Product Description: Miscellaneous
Table of Contents
Chapter Goals
Simple Network Management Protocol
Background
SNMP Basic Components
SNMP Basic Commands
SNMP Management Information Base
SNMP and Data Representation
SNMP Version 1
SNMPv1 and Structure of Management Information
SNMPv1 and ASN.1 Data Types
SNMP MIB Tables
SNMPv1 Protocol Operations
SNMP Version 2
SNMPv2 and Structure of Management Information
SMI Information Modules
SNMPv2 Protocol Operations
SNMP Management
SNMP Security
SNMP Interoperability
Proxy Agents
Bilingual Network-Management System
SNMP Reference: SNMPv1 Message Formats
SNMPv1 Message Header
SNMPv1 Protocol Data Unit
Trap PDU Format
SNMP Reference: SNMPv2 Message Format
SNMPv2 Message Header
SNMPv2 Protocol Data Unit
GetBulk PDU Format
Review Questions
Chapter Goals
Discuss the SNMP Management Information Base.
Describe SNMP version 1.
Describe SNMP version 2.
Background
The Simple Network Management Protocol (SNMP) is an application layer protocol that facilitates the exchange of management information between network devices. It is part of the Transmission Control Protocol/Internet Protocol (TCP/IP) protocol suite. SNMP enables network administrators to manage network performance, find and solve network problems, and plan for network growth.
Two versions of SNMP exist: SNMP version 1 (SNMPv1) and SNMP version 2 (SNMPv2). Both versions have a number of features in common, but SNMPv2 offers enhancements, such as additional protocol operations. Standardization of yet another version of SNMP—SNMP Version 3 (SNMPv3)—is pending. This chapter provides descriptions of the SNMPv1 and SNMPv2 protocol operations. Figure 56-1 illustrates a basic network managed by SNMP.
Figure 56-1: SNMP Facilitates the Exchange of Network Information Between Devices
An SNMP-managed network consists of three key components: managed devices, agents, and network-management systems (NMSs).
A managed device is a network node that contains an SNMP agent and that resides on a managed network. Managed devices collect and store management information and make this information available to NMSs using SNMP. Managed devices, sometimes called network elements, can be routers and access servers, switches and bridges, hubs, computer hosts, or printers.
An agent is a network-management software module that resides in a managed device. An agent has local knowledge of management information and translates that information into a form compatible with SNMP.
An NMS executes applications that monitor and control managed devices. NMSs provide the bulk of the processing and memory resources required for network management. One or more NMSs must exist on any managed network.
Figure 56-2 illustrates the relationships of these three components.
Figure 56-2: An SNMP-Managed Network Consists of Managed Devices, Agents, and NMSs
SNMP Basic Commands
Managed devices are monitored and controlled using four basic SNMP commands: read, write, trap, and traversal operations.
The read command is used by an NMS to monitor managed devices. The NMS examines different variables that are maintained by managed devices.
The write command is used by an NMS to control managed devices. The NMS changes the values of variables stored within managed devices.
The trap command is used by managed devices to asynchronously report events to the NMS. When certain types of events occur, a managed device sends a trap to the NMS.
Traversal operations are used by the NMS to determine which variables a managed device supports and to sequentially gather information in variable tables, such as a routing table.
A Management Information Base (MIB) is a collection of information that is organized hierarchically. MIBs are accessed using a network-management protocol such as SNMP. They are comprised of managed objects and are identified by object identifiers.
A managed object (sometimes called a MIB object, an object, or a MIB) is one of any number of specific characteristics of a managed device. Managed objects are comprised of one or more object instances, which are essentially variables.
Two types of managed objects exist: scalar and tabular. Scalar objects define a single object instance. Tabular objects define multiple related object instances that are grouped in MIB tables.
An example of a managed object is atInput, which is a scalar object that contains a single object instance, the integer value that indicates the total number of input AppleTalk packets on a router interface.
An object identifier (or object ID) uniquely identifies a managed object in the MIB hierarchy. The MIB hierarchy can be depicted as a tree with a nameless root, the levels of which are assigned by different organizations. Figure 56-3 illustrates the MIB tree.
The top-level MIB object IDs belong to different standards organizations, while lower-level object IDs are allocated by associated organizations.
Vendors can define private branches that include managed objects for their own products. MIBs that have not been standardized typically are positioned in the experimental branch.
The managed object atInput can be uniquely identified either by the object name—iso.identified-organization.dod.internet.private.enterprise.cisco.temporary variables.AppleTalk.atInput—or by the equivalent object descriptor, 1.3.6.1.4.1.9.3.3.1.
Figure 56-3: The MIB Tree Illustrates the Various Hierarchies Assigned by Different Organizations
SNMP must account for and adjust to incompatibilities between managed devices. Different computers use different data representation techniques, which can compromise the capability of SNMP to exchange information between managed devices. SNMP uses a subset of Abstract Syntax Notation One (ASN.1) to accommodate communication between diverse systems.
SNMP Version 1
is the initial implementation of the SNMP protocol. It is described in Request For Comments (RFC) 1157 and functions within the specifications of the Structure of Management Information (SMI). SNMPv1 operates over protocols such as User Datagram Protocol (UDP), Internet Protocol (IP), OSI Connectionless Network Service (CLNS), AppleTalk Datagram-Delivery Protocol (DDP), and Novell Internet Packet Exchange (IPX). SNMPv1 is widely used and is the de facto network-management protocol in the Internet community.SNMPv1 and Structure of Management Information
The Structure of Management Information (SMI) defines the rules for describing management information, using Abstract Syntax Notation One (ASN.1). The SNMPv1 SMI is defined in RFC 1155. The SMI makes three key specifications: ASN.1 data types, SMI-specific data types, and SNMP MIB tables.
The SNMPv1 SMI specifies that all managed objects have a certain subset of Abstract Syntax Notation One (ASN.1) data types associated with them. Three ASN.1 data types are required: name, syntax, and encoding. The name serves as the object identifier (object ID). The syntax defines the data type of the object (for example, integer or string). The SMI uses a subset of the ASN.1 syntax definitions. The encoding data describes how information associated with a managed object is formatted as a series of data items for transmission over the network.
SNMPv1 and SMI-Specific Data Types
The SNMPv1 SMI specifies the use of a number of SMI-specific data types, which are divided into two categories: simple data types and application-wide data types.
Three simple data types are defined in the SNMPv1 SMI, all of which are unique values: integers, octet strings, and object IDs. The integer data type is a signed integer in the range of -2,147,483,648 to 2,147,483,647. Octet strings are ordered sequences of 0 to 65,535 octets. Object IDs come from the set of all object identifiers allocated according to the rules specified in ASN.1.
Seven application-wide data types exist in the SNMPv1 SMI: network addresses, counters, gauges, time ticks, opaques, integers, and unsigned integers. Network addresses represent an address from a particular protocol family. SNMPv1 supports only 32-bit IP addresses. Counters are non-negative integers that increase until they reach a maximum value and then return to zero. In SNMPv1, a 32-bit counter size is specified. Gauges are non-negative integers that can increase or decrease but that retain the maximum value reached. A time tick represents a hundredth of a second since some event. An opaque represents an arbitrary encoding that is used to pass arbitrary information strings that do not conform to the strict data typing used by the SMI. An integer represents signed integer-valued information. This data type redefines the integer data type, which has arbitrary precision in ASN.1 but bounded precision in the SMI. An unsigned integer represents unsigned integer-valued information and is useful when values are always non-negative. This data type redefines the integer data type, which has arbitrary precision in ASN.1 but bounded precision in the SMI.
SNMP MIB Tables
The SNMPv1 SMI defines highly structured tables that are used to group the instances of a tabular object (that is, an object that contains multiple variables). Tables are composed of zero or more rows, which are indexed in a way that allows SNMP to retrieve or alter an entire row with a single Get, GetNext, or Set command.
SNMP is a simple request/response protocol. The network-management system issues a request, and managed devices return responses. This behavior is implemented by using one of four protocol operations: Get, GetNext, Set, and Trap. The Get operation is used by the NMS to retrieve the value of one or more object instances from an agent. If the agent responding to the Get operation cannot provide values for all the object instances in a list, it does not provide any values. The GetNext operation is used by the NMS to retrieve the value of the next object instance in a table or a list within an agent. The Set operation is used by the NMS to set the values of object instances within an agent. The Trap operation is used by agents to asynchronously inform the NMS of a significant event.
SNMP Version 2
is an evolution of the initial version, SNMPv1. Originally, SNMPv2 was published as a set of proposed Internet standards in 1993; currently, it is a draft standard. As with SNMPv1, SNMPv2 functions within the specifications of the Structure of Management Information (SMI). In theory, SNMPv2 offers a number of improvements to SNMPv1, including additional protocol operations.SNMPv2 and Structure of Management Information
The Structure of Management Information (SMI) defines the rules for describing management information, using ASN.1.
The SNMPv2 SMI is described in RFC 1902. It makes certain additions and enhancements to the SNMPv1 SMI-specific data types, such as including bit strings, network addresses, and counters. Bit strings are defined only in SNMPv2 and comprise zero or more named bits that specify a value. Network addresses represent an address from a particular protocol family. SNMPv1 supports only 32-bit IP addresses, but SNMPv2 can support other types of addresses as well. Counters are non-negative integers that increase until they reach a maximum value and then return to zero. In SNMPv1, a 32-bit counter size is specified. In SNMPv2, 32-bit and 64-bit counters are defined.
The SNMPv2 SMI also specifies information modules, which specify a group of related definitions. Three types of SMI information modules exist: MIB modules, compliance statements, and capability statements. MIB modules contain definitions of interrelated managed objects. Compliance statements provide a systematic way to describe a group of managed objects that must be implemented for conformance to a standard. Capability statements are used to indicate the precise level of support that an agent claims with respect to a MIB group. An NMS can adjust its behavior toward agents according to the capabilities statements associated with each agent.
The Get, GetNext, and Set operations used in SNMPv1 are exactly the same as those used in SNMPv2. However, SNMPv2 adds and enhances some protocol operations. The SNMPv2 Trap operation, for example, serves the same function as that used in SNMPv1, but it uses a different message format and is designed to replace the SNMPv1 Trap.
SNMPv2 also defines two new protocol operations: GetBulk and Inform. The GetBulk operation is used by the NMS to efficiently retrieve large blocks of data, such as multiple rows in a table. GetBulk fills a response message with as much of the requested data as will fit. The Inform operation allows one NMS to send trap information to another NMS and to then receive a response. In SNMPv2, if the agent responding to GetBulk operations cannot provide values for all the variables in a list, it provides partial results.
SNMP Management
SNMP is a distributed-management protocol. A system can operate exclusively as either an NMS or an agent, or it can perform the functions of both. When a system operates as both an NMS and an agent, another NMS might require that the system query manage devices and provide a summary of the information learned, or that it report locally stored management information.
SNMP Security
SNMP lacks any authentication capabilities, which results in vulnerability to a variety of security threats. These include masquerading occurrences, modification of information, message sequence and timing modifications, and disclosure. Masquerading consists of an unauthorized entity attempting to perform management operations by assuming the identity of an authorized management entity. Modification of information involves an unauthorized entity attempting to alter a message generated by an authorized entity so that the message results in unauthorized accounting management or configuration management operations. Message sequence and timing modifications occur when an unauthorized entity reorders, delays, or copies and later replays a message generated by an authorized entity. Disclosure results when an unauthorized entity extracts values stored in managed objects, or learns of notifiable events by monitoring exchanges between managers and agents. Because SNMP does not implement authentication, many vendors do not implement Set operations, thereby reducing SNMP to a monitoring facility.
As presently specified, SNMPv2 is incompatible with SNMPv1 in two key areas: message formats and protocol operations. SNMPv2 messages use different header and protocol data unit (PDU) formats than SNMPv1 messages. SNMPv2 also uses two protocol operations that are not specified in SNMPv1. Furthermore, RFC 1908 defines two possible SNMPv1/v2 coexistence strategies: proxy agents and bilingual network-management systems.
Proxy Agents
An SNMPv2 agent can act as a proxy agent on behalf of SNMPv1 managed devices, as follows:
An SNMPv2 NMS issues a command intended for an SNMPv1 agent.
The NMS sends the SNMP message to the SNMPv2 proxy agent.
The proxy agent forwards Get, GetNext, and Set messages to the SNMPv1 agent unchanged.
GetBulk messages are converted by the proxy agent to GetNext messages and then are forwarded to the SNMPv1 agent.
The proxy agent maps SNMPv1 trap messages to SNMPv2 trap messages and then forwards them to the NMS.
Bilingual SNMPv2 network-management systems support both SNMPv1 and SNMPv2. To support this dual-management environment, a management application in the bilingual NMS must contact an agent. The NMS then examines information stored in a local database to determine whether the agent supports SNMPv1 or SNMPv2. Based on the information in the database, the NMS communicates with the agent using the appropriate version of SNMP.
SNMPv1 messages contain two parts: a message header and a protocol data unit (PDU). Figure 56-4 illustrates the basic format of an SNMPv1 message.
Figure 56-4: An SNVPv1 Message Consists of a Header and a PDU
SNMPv1 message headers contain two fields: Version Number and Community Name.
The following descriptions summarize these fields:
Version number
—Specifies the version of SNMP used.Community name
—Defines an access environment for a group of NMSs. NMSs within the community are said to exist within the same administrative domain. Community names serve as a weak form of authentication because devices that do not know the proper community name are precluded from SNMP operations.SNMPv1 Protocol Data Unit
SNMPv1 PDUs contain a specific command (Get, Set, and so on) and operands that indicate the object instances involved in the transaction. SNMPv1 PDU fields are variable in length, as prescribed by ASN.1. Figure 56-5 illustrates the fields of the SNMPv1 Get, GetNext, Response, and Set PDUs transactions.
Figure 56-5: SNMPv1 Get, GetNext, Response, and Set PDUs Contain the Same Fields
The following descriptions summarize the fields illustrated in Figure 56-5:
PDU type
—Specifies the type of PDU transmitted.Request ID
—Associates SNMP requests with responses.Error status
—Indicates one of a number of errors and error types. Only the response operation sets this field. Other operations set this field to zero.Error index
—Associates an error with a particular object instance. Only the response operation sets this field. Other operations set this field to zero.Variable bindings
—Serves as the data field of the SNMPv1 PDU. Each variable binding associates a particular object instance with its current value (with the exception of Get and GetNext requests, for which the value is ignored).Trap PDU Format
Figure 56-6 illustrates the fields of the SNMPv1 Trap PDU.
Figure 56-6: The SNMPv1 Trap PDU Consists of Eight Fields
The following descriptions summarize the fields illustrated in Figure 56-6:
Enterprise
—Identifies the type of managed object generating the trap.Agent address
—Provides the address of the managed object generating the trap.Generic trap type
—Indicates one of a number of generic trap types.Specific trap code
—Indicates one of a number of specific trap codes.Time stamp
—Provides the amount of time that has elapsed between the last network reinitialization and generation of the trap.Variable bindings
—The data field of the SNMPv1 Trap PDU. Each variable binding associates a particular object instance with its current value.SNMP Reference: SNMPv2 Message Format
SNMPv2 messages consist of a header and a PDU. Figure 56-7 illustrates the basic format of an SNMPv2 message.
Figure 56-7: SNMPv2 Messages Also Consist of a Header and a PDU
SNMPv2 message headers contain two fields: Version Number and Community Name.
Version number
—Specifies the version of SNMP that is being used.Community name
—Defines an access environment for a group of NMSs. NMSs within the community are said to exist within the same administrative domain. Community names serve as a weak form of authentication because devices that do not know the proper community name are precluded from SNMP operations.SNMPv2 Protocol Data Unit
SNMPv2 specifies two PDU formats, depending on the SNMP protocol operation. SNMPv2 PDU fields are variable in length, as prescribed by Abstract Syntax Notation One (ASN.1).
Figure 56-8 illustrates the fields of the SNMPv2 Get, GetNext, Inform, Response, Set, and Trap PDUs.
The following descriptions summarize the fields illustrated in Figure 56-8:
PDU type
—Identifies the type of PDU transmitted (Get, GetNext, Inform, Response, Set, or Trap).Request ID
—Serves as the data field of the SNMPv2 PDU. Each variable binding associates a particular object instance with its current value (with the exception of Get and GetNext requests, for which the value is ignored).
Figure 56-8: SNMPv2 Get, GetNext, Inform, Response, Set, and Trap PDUs Contain the Same Fields
GetBulk PDU Format
Figure 56-9 illustrates the fields of the SNMPv2 GetBulk PDU.
Figure 56-9: The SNMPv2 GetBulk PDU Consists of Seven Fields
The following descriptions summarize the fields illustrated in Figure 56-9:
PDU type
—Identifies the PDU as a GetBulk operation.Request ID
—Associates SNMP requests with responses.Non repeaters
—Specifies the number of object instances in the variable bindings field that should be retrieved no more than once from the beginning of the request. This field is used when some of the instances are scalar objects with only one variable.Max repetitions
—Defines the maximum number of times that other variables beyond those specified by the Non repeaters field should be retrieved.Variable bindings
—Serves as the data field of the SNMPv2 PDU. Each variable binding associates a particular object instance with its current value (with the exception of Get and GetNext requests, for which the value is ignored).Review Questions
Q—
What are MIBs, and how are they accessed?A—
A Management Information Base (MIB) is a collection of information that is organized hierarchically. MIBs are accessed using a network-management protocol such as SNMP. They are comprised of managed objects and are identified by object identifiers.Q—
SNMP uses a series of and _to manage the network.A—
Gets and Puts. SNMP uses a Get object and a Put object to manage devices on a network such as get counters.Q—
Name three of the seven fields of the SNMP v2 GETBULK.A—
PDU Type, Request ID, Nonrepeaters, Max Repetitions, Variable Bindings (the variable bindings consists of variable object fields that make up the three remaining fields).
Posted: Wed Feb 20 21:37:27 PST 2002
All contents are Copyright © 1992--2002 Cisco Systems, Inc. All rights reserved.
Important Notices
and Privacy Statement.
