Product: Vtrak 15100
Platform: Independent
Additional Description: See attachment
WebPAM Events
NS - Not Supported
NT - Not Tested
S3.1 – Supported in SR3.1
Severity Level is according to WebPAM not related with firmware
Event ID |
Event Description |
Severity Level |
02.00.0000.00 |
02.01.0000.00 |
02.03.0000.15 |
Event Subscription & Email |
Event frame |
Event Subscription & EmailEvent frameEvent Subscription & EmailEvent frame | |||
Controller Events |
458753 |
Data Parity Error |
Yes |
Yes |
YesYesYesYes | |
458754 |
Command Parity Error |
Yes |
Yes |
YesYesYesYes | |
458755 |
Bus Reset |
Yes |
Yes |
YesYesYesYes | |
458756 |
Unrecoverable Error |
Yes |
Yes |
YesYesYesYes | |
458757 |
Abort task |
Yes |
Yes |
YesYesYesYes | |
458759 |
Clear ACA |
Yes |
Yes |
YesYesYesYes | |
458761 |
LUN Reset |
Yes |
Yes |
YesYesYesYes | |
458762 |
Initiator Error |
Yes |
Yes |
YesYesYesYes | |
458763 |
Illegal Secondary Identify |
Yes |
Yes |
YesYesYesYes | |
458764 |
Message Parity Error |
Yes |
Yes |
YesYesYesYes | |
458765 |
Bus Reboot |
Yes |
Yes |
YesYesYesYes | |
Ultratrak Events |
101 |
Ultratrak Connection Connected |
Yes |
Yes |
YesYesYesYes | |
102 |
Ultratrak Connection Lost |
Yes |
Yes |
YesYesYesYes | |
Disk Events |
851969 |
Fatal Error |
NS /S3.1 |
Yes |
NS YesYesYes | |
851970 |
Disk Down |
Critical |
Yes |
Yes (Same as Disk Removed) |
Yes NS(Same as Disk Removed) YesNS(Same as Disk Removed) |
851978 |
Disk Plugged In |
Yes |
Yes |
YesYesYesYes | |
851979 |
Disk Removed |
Yes |
NS |
YesYesYesYes | |
851980 |
Disk Access Retry |
Yes |
Yes |
YesYesYesYes | |
851982 |
Disk CRC Error |
Yes |
Yes |
YesYesYesYes | |
1048576 |
Disk S.M.A.R.T. Failed |
Critical |
Yes |
Yes |
YesYesYesYes |
851981 |
Disk ECC Error |
Yes |
Yes |
YesYesYesYes | |
851983 |
Disk Bad Sector |
Critical |
Yes |
Yes |
YesYesYesYes |
851984 |
Disk Reserve Sector Error |
Yes |
Yes |
YesYesYesYes | |
851985 |
Disk Time out |
Yes |
Yes |
YesYesYesYes | |
1835010 |
Wipe Out Boot Sector |
Critical |
NS/ S3.1 |
Yes |
NS YesYesYes |
1835009 |
Wipe Out Reserved Sector |
Critical |
NS/ S3.1 |
Yes |
NS YesYesYes |
DiskArray Events |
1245184 |
Create Disk Array |
NS (See Create LD) |
NS |
NS (See Create LD) NSYesYes | |
1245185 |
Delete Disk Array |
NS (See Delete LD) |
NS |
NS (See Delete LD) NSYesYes | |
589828 |
Disk Array Critical |
Critical |
Yes |
Yes |
YesYesYesYes |
589827 |
Disk Array Offline |
Critical |
Yes |
Yes |
YesYesYesYes |
786432 |
Migration Started |
Yes |
Yes |
YesYesYesYes | |
786433 |
Migration Completed |
Yes |
Yes |
YesYesYesYes | |
786436 |
Migration Stopped |
Yes |
Yes |
YesYesYesYes | |
983040 |
Rebuild Started |
Yes |
Yes |
YesYesYesYes | |
983041 |
Rebuild Completed |
Yes |
Yes |
YesYesYesYes | |
983047 |
Rebuild Aborted |
Yes |
Yes |
YesYesYesYes | |
196608 |
Redundancy Check Started |
NS/ S3.1 |
Yes |
NS YesYesYes | |
196609 |
Redundancy Check Completed |
NS/ S3.1 |
Yes |
NS YesYesYes | |
196614 |
Redundancy Check Aborted |
NS/ S3.1 |
Yes |
NS YesYesYes | |
196610 |
Redundancy Check Paused |
NS/ S3.1 |
Yes |
NS YesYesYes | |
196611 |
Redundancy Check Resumed |
NS/ S3.1 |
Yes |
NS YesYesYes | |
196615 |
Redundancy Check Inconsistent Stripe |
Critical |
NS/ S3.1 |
Yes |
NS YesYesYes |
1179648 |
Synchronization Started |
Yes |
Yes |
YesYesYesYes | |
1179649 |
Synchronization Completed |
Yes |
Yes |
YesYesYesYes | |
1179653 |
Synchronization Aborted |
Yes |
Yes |
YesYesYesYes | |
1179650 |
Synchronization Paused |
NS/ S3.1 |
Yes |
NS YesYesYes | |
1179651 |
Synchronization Resumed |
NS/ S3.1 |
Yes |
NS YesYesYes | |
1769472 |
PDM Started |
NS/ S3.1 |
Yes |
NS YesYesYes | |
1769473 |
PDM Completed |
NS/ S3.1 |
Yes |
NS YesYesYes | |
1769477 |
PDM Aborted |
NS/ S3.1 |
Yes |
NS YesYesYes | |
524288 |
Full Initialization Start |
Yes |
Yes |
YesYesYesYes | |
524289 |
Full Initialization Completed |
Yes |
Yes |
YesYesYesYes | |
524292 |
Full Initialization Stopped |
Yes |
Yes |
YesYesYesYes | |
524295 |
Quick Initialization Start |
Yes |
Yes |
YesYesYesYes | |
524296 |
Quick Initialization Completed |
Yes |
Yes |
YesYesYesYes | |
524299 |
Quick Initialization Stopped |
Yes |
Yes |
YesYesYesYes | |
99 |
Percent Completed |
Yes |
Yes |
YesYesYesYes | |
LogicalDrive Events |
589834 |
Create Logical Drive |
Yes |
Yes |
YesYesYesYes | |
589835 |
Delete Logical Drive |
Yes |
Yes |
YesYesYesYes | |
589832 |
Yes |
Yes |
YesYesYesYes | |
589833 |
Yes |
Yes |
YesYesYesYes | |
Enclosure Events |
917508 |
Enclosure Power Down |
Yes |
Yes |
YesYesYesYes | |
917507 |
Enclosure Power Up |
Yes |
Yes |
YesYesYesYes | |
917504 |
Power Supply Not Present |
NS/ S3.1 |
Yes |
NS YesYesYes | |
1114115 |
Enclosure Over Temperature |
Critical |
Yes |
Yes |
YesYesYesYes |
327681 |
Enclosure Fan Stop |
Critical |
Yes |
NS |
Yes NSYesNS |
327685 |
Cooling Device Inserted |
NS/ S3.1 |
NS/ S3.1 |
NS YesYesYes | |
327686 |
Cooling Device Removed |
NS/ S3.1 |
NS/ S3.1 |
NS YesYesYes | |
1114114 |
Enclosure 3.3V Out of Range |
Yes |
NS |
Yes NSYesNS | |
1114113 |
Enclosure 5.0V Out of Range |
Critical |
Yes |
Yes |
YesYesYesYes |
1114112 |
Enclosure 12.0V Out of Range |
Critical |
Yes |
Yes |
YesYesYesYes |
65548 |
Battery Inserted |
NS/ S3.1 |
NS/ S3.1 |
NSNS YesYes | |
65547 |
Battery Removed |
NS/ S3.1 |
NS/ S3.1 |
NSNS YesYes | |
65536 |
Battery Temperature Out of Range |
Yes |
Yes |
YesYesYesYes | |
65537 |
Battery Temperature Back to Normal |
Yes |
Yes |
YesYesYesYes | |
65538 |
Battery Capacity Below Threshold |
Yes |
Yes |
YesYesYesYes | |
65539 |
Battery Capacity Normal |
Yes |
Yes |
YesYesYesYes | |
65540 |
Battery Discharging |
Yes |
Yes |
YesYesYesYes | |
65541 |
Battery Charging |
Yes |
Yes |
YesYesYesYes | |
65542 |
Battery Maintenance Mode |
Yes |
Yes |
YesYesYesYes | |
65546 |
Battery Life Ended |
Yes |
Yes |
YesYesYesYes |
