This article contains a script used to configure Promise VTrak RAID Controllers and SAS-connected Expansion Chassis: Xsan (Metadata and Data) configuration script - E5800f + J5600s
#Begin Copy
# Promise VTrak E5800f + J5600s Configuration Script
# Script Name: RAID Controllers and 1 SAS-connected Expansion Chassis: Xsan (Metadata and Data)
# Script Details: builds 6 LUNs from 40 drives (head + 1 expansion units)
# Global controller settings
# ALUA: enabled [required]
# Delete any existing arrays
# Delete array 0 thru 5
#array -a del -d 0
#array -a del -d 1
#array -a del -d 2
#array -a del -d 3
#array -a del -d 4
#array -a del -d 5
# Build MDC LUN
# RAID level: 1
# Physical Drives: 1, 2
# Alias: MDC
# Controller Affinity: 1
# Build Audio/Scratch LUN
# RAID level: 5
# Physical Drives: 21, 22, 23, 24
# Alias: Scratch
# Controller Affinity: 2
array -a add -p 21,22,23,24 -s "alias=Scratch" -l "alias=Scratch, raid=5, readpolicy=readahead, writepolicy=writeback, preferredctrlid=2"
# Build Data1 LUN
# RAID level: 6
# Physical Drives: 5, 6, 9, 10, 13, 14, 17, 18
# Alias: Data1
# Configuration options: Capacity all (default), 1MB stripe size,
array -a add -p 5,6,9,10,13,14,17,18 -s "alias=Data1" -l "alias=Data1, raid=6, stripe=1mb, readpolicy=readahead, writepolicy=writeback, preferredctrlid=1"
# Build Data2 LUN
# RAID level: 6
# Physical Drives: 7, 8, 11, 12, 15, 16, 19, 20
# Alias: Data2
array -a add -p 7,8,11,12,15,16,19,20 -s "alias=Data2" -l "alias=Data2, raid=6, stripe=1mb, readpolicy=readahead, writepolicy=writeback, preferredctrlid=2"
# Build Data3 LUN
# RAID level: 6
# Physical Drives: 25, 26, 29, 30, 33, 34, 37, 38
# Alias: Data3
array -a add -p 25,26,29,30,33,34,37,38 -s "alias=Data3" -l "alias=Data3, raid=6, stripe=1mb, readpolicy=readahead, writepolicy=writeback, preferredctrlid=1"
# Build Data4 LUN
# RAID level: 6
# Physical Drives: 27, 28, 31, 32, 35, 36, 39, 40
# Alias: Data4
array -a add -p 27,28,31,32,35,36,39,40 -s "alias=Data4" -l "alias=Data4, raid=6, stripe=1mb, readpolicy=readahead, writepolicy=writeback, preferredctrlid=2"
# Set up global spares
# Physical Drives: 3, 4
# Type: Global spares, Revertible
spare -a add -p 3 -t g -r y
spare -a add -p 4 -t g -r y
init -a start -l 0 -q 100
init -a start -l 1 -q 100
init -a start -l 2 -q 100
init -a start -l 3 -q 100
init -a start -l 4 -q 100
init -a start -l 5 -q 100
# END
#End Copy
For more information about options configured by this script, see Promise VTrak: Configuring for Optimal Performance (E5000 Series)
