Product: VTrak 15200
Product Description: VTrak 15100/15200
Platform: Independent
Additional Description: Attached is firmware image file: vtrak-02.00.0001.02.img
Changes history for VTrak 15200 SR3.1 FW (v2.00.0001.02) – 2/25/2005
1. Fix Hitachi and Seagate SATA HDD compatibility issues
2. Fix the SEP1 battery LED status bug
3. Remove the support of sector size above 4KB
Changes history for VTrak 15200 SR3.1 FW (v2.00.0001.01) – 2/9/2005
1. Rebuild RAID API library with a correct makefile. No source code changes at all in this release.
Changes history for VTrak 15200 SR3.1 FW (v2.00.0001.00) – 1/31/2005
1. Flushing CPU cache properly to ensure data integrity. It fixes FRAM data corruption issue.
2. Removing HDD far loop-back test so Segate NCQ drives can be seen by the system.
3. Adding FAN box and Battery plug-in/plug-out events
4. CIMOM agent is slightly modified to handle the new events.
