# CONFIGURATION SCRIPT BEGIN
# Script Date:    Jun 5, 2015 09:08:10
# Script Summary: The configuration script is used to save the current RAID
#                 configuration, which can be later used for various purpose like
#                 - Propagating the saved configuration to other subsystems
#                 - Restoring a system configuration, lost due to some failure
#                 - The script can serve as summary of the system configuration
#                    if needed to troubleshoot a failure condition.
# Source Subsystem Configuration Overview:
#       Subsystem Model:               Vess R2600ti
#       Reduancy Type:                 1
#       Controllers Count:             2
#            Controller ID:            1
#                Firmware Version:     1.04.0000.07
#                Software Version:     1.04.0000.07
#                Controller Mode:      0
#            Controller ID:            2
#       Physical Drives Count:         32
#            PD ID    Physical Capacity    Type
#               1        1.81 TB           SAS HDD
#               2        1.81 TB           SAS HDD
#               3        1.81 TB           SAS HDD
#               4        1.81 TB           SAS HDD
#               5        1.81 TB           SAS HDD
#               6        1.81 TB           SAS HDD
#               7        1.81 TB           SAS HDD
#               8        1.81 TB           SAS HDD
#               9        1.81 TB           SAS HDD
#              10        1.81 TB           SAS HDD
#              11        1.81 TB           SAS HDD
#              12        1.81 TB           SAS HDD
#              13        1.81 TB           SAS HDD
#              14        1.81 TB           SAS HDD
#              15        1.81 TB           SAS HDD
#              16        1.81 TB           SAS HDD
#              17        1.81 TB           SAS HDD
#              18        1.81 TB           SAS HDD
#              19        1.81 TB           SAS HDD
#              20        1.81 TB           SAS HDD
#              21        1.81 TB           SAS HDD
#              22        1.81 TB           SAS HDD
#              23        1.81 TB           SAS HDD
#              24        1.81 TB           SAS HDD
#              25        1.81 TB           SAS HDD
#              26        1.81 TB           SAS HDD
#              27        1.81 TB           SAS HDD
#              28        1.81 TB           SAS HDD
#              29        1.81 TB           SAS HDD
#              30        1.81 TB           SAS HDD
#              31        1.81 TB           SAS HDD
#              32        1.81 TB           SAS HDD
# Script Prerequisites for the Target Subsystem:
#       - Target Subsystem must have similar configuration as Source Subsystem
#       - Any exsiting configuration must be deleted from the Target Subsystem for
#         the script to run without errors
# ADVISORY NOTE :
#     PLEASE USE EXTREME CAUTION WHILE EDITING THIS FILE.
#     MODIFICATION RELATED TO STORAGE CONFIGURATION MAY POTENTIALLY PRODUCE
#     UNPREDICTABLE RESULTS OR DATA LOSS ON PRODUCTION SYSTEMS.
#     PROMISE STRONGLY RECOMMENDS TESTING ALL USER MODIFIED SCRIPTS ON
#     NON-PRODUCTION SYSTEM, BEFORE USING IT ON PRODUCTION SYSTEMS.
# Array Configuration
diskpool -a add -n "DP2" -r 6 -p 17,18,19,20,21,22,23,24,25,26,27,28,29,30,31 -s"ctrlid=2,stripe=1024KB"
sharedisk -a add -n "SD2" -d "DP2" -t sd -c 100tb -p smb|webdav|nfs|ftp|afp -u enable -r rw
spare -a add -i 0 -p 32 -r y -t g -s "mediapatrol=enable"
# CONFIGURATION SCRIPT END
