Products Affected:
- SuperTrak EX8654
- SuperTrak EX8658
Conditions:
Attach Promise VTrak J310s/J610s or other manufacturer's JBOD chassis to increase the number of physical drive more than 32.
Failure Mode/Symptom:
Users can only select 32 physical drives to create Disk Array from controller BIOS.
Solution/Workaround:
Users need to install and configure Disk Array and Logical Drive via WebPAM PRO or CLI utility.
Additional Comments:
This issue is due to limitations of memory usage in the controller BIOS.
