Introduction
RAID configurations are tailored to meet diverse storage needs, balancing performance and data protection. On the Promise Pegasus Series, RAID 0 is a popular choice for maximizing performance and capacity by striping data across multiple drives. However, RAID 0 lacks redundancy, meaning a single drive failure results in complete data loss.
Why RAID 0 Cannot Be Rebuilt
RAID 0 enhances performance by splitting data into "stripes" and writing them across all drives in the array. Unlike redundant RAID levels like RAID 1 or RAID 5, RAID 0 does not store parity or duplicate data. As a result:
  1. No Redundancy: There are no backups or parity data within the array.
  2. Dependency on All Drives: The array requires all drives to function. A single failure makes the entire dataset unrecoverable.
  3. No Rebuild Mechanism: Without redundancy, there is no way to reconstruct the lost data.
Summary: RAID 0 prioritizes performance and capacity over data protection, making it impossible to rebuild after a drive failure.
Alternative Solutions
For users considering RAID 0 on their Pegasus, or those already using it, the following measures can help protect your data:
1. Maintain Regular Backups
  • RAID 0 lacks redundancy, so backups are essential.
  • Use external drives, NAS devices, or cloud storage to ensure up-to-date copies of your data.
2. Use a Redundant RAID Level
  • If data protection is a priority, opt for RAID levels like RAID 5, or RAID 6.
  • These configurations offer a balance of performance and redundancy, safeguarding against drive failures.
3. Monitor Drive Health
  • Use the Promise Utility to monitor drive status and performance.
  • Replace drives that show signs of degradation to prevent sudden failures.
4. Consider a Hybrid Approach
  • Combine RAID 0 with RAID 1 in a RAID 10 setup to merge the performance of RAID 0 with the redundancy of RAID 1.
  • While this requires additional drives, it ensures data protection without compromising speed.
Conclusion
RAID 0 on the Pegasus is ideal for performance but unsuitable for data protection. Its lack of redundancy means rebuilding is not an option after a drive failure. To mitigate risks, ensure you:
  • Maintain regular backups.
  • Choose a RAID level that meets your redundancy needs.
  • Monitor and proactively manage drive health.
