How to reset the Default Password for VR3600 Storage
This feature resets the Administrator’s password to the default factory setting, password. Use this feature when you have forgotten Administrator’s password, or a new Administrator has been appointed.
The reset applies to the Administrator’s login for WebPAM PROe and the CLI. No other user passwords are affected.
To reset the Administrator’s default password:
- Verify that the Vess has fully booted.
- For one of the RAID controllers, locate the password reset switch. See illustration below.
- Insert a pin or a straightened paper clip into the opening and momentarily depress password reset switch.
You only need to press the reset switch on one RAID controller.
The next time the Administrator logs in, use the default password: password.
Important: PROMISE recommends that you change the Administrator’s default password immediately after reset.
