This article contains a script used to configure Promise VTrak E5600f RAID Controllers for Xsan (Metadata and Data).
#Begin Copy
# Promise VTrak E5600f Configuration Script
# Script Name: RAID Controllers: Xsan (Metadata and Data)
# Script Details: builds 3 LUNs from 16 drives (head units)
# Global controller settings
# ALUA: enabled [required]
# Delete any existing arrays
# Delete array 0 thru 2
#array -a del -d 0
#array -a del -d 1
#array -a del -d 2
# Build MDC LUN
# RAID level: 1
# Physical Drives: 1, 2
# Alias: MDC
# Controller Affinity: 1
# Build Data1 LUN
# RAID level: 5
# Physical Drives: 5, 6, 9, 10, 13, 14
# Alias: Data1
# Controller Affinity: 2
# Configuration options: Capacity all (default), 1MB stripe size,
array -a add -p 5,6,9,10,13,14 -s "alias=Data1" -l "alias=Data1, raid=5, stripe=1mb, readpolicy=readahead, writepolicy=writeback, preferredctrlid=2"
# Build Data2 LUN
# RAID level: 5
# Physical Drives: 7, 8, 11, 12, 15, 16
# Alias: Data2
array -a add -p 7,8,11,12,15,16 -s "alias=Data2" -l "alias=Data2, raid=5, stripe=1mb, readpolicy=readahead, writepolicy=writeback, preferredctrlid=1"
# Set up global spares
# Physical Drives: 3, 4
# Type: Global spares, Revertible
spare -a add -p 3 -t g -r y
spare -a add -p 4 -t g -r y
init -a start -l 0 -q 100
init -a start -l 1 -q 100
init -a start -l 2 -q 100
# END
#End Copy
For more information about options configured by this script, see Promise VTrak: Configuring for Optimal Performance (E5000 Series)
