This article contains a script used to configure Promise VTrak E5320f RAID Controllers for Xsan (Metadata and Data).
#Begin Copy
# Promise VTrak E5320f Configuration Script
# Script Name: RAID Controllers Only: Xsan (Metadata and Data)
# Script Details: builds 3 LUNs from 24 drives (head units)
# Global controller settings
# ALUA: enabled [required]
# Delete any existing arrays
# Delete array 0 thru 3
#array -a del -d 0
#array -a del -d 1
#array -a del -d 2
#array -a del -d 3
# Build MDC LUN
# RAID level: 1
# Physical Drives: 1, 2
# Alias: MDC
# Controller Affinity: 1
# Build Data1 LUN
# RAID level: 5
# Physical Drives: 5,6,7,8,9,10,11,12,13,14
# Alias: Data1
array -a add -p 5,6,7,8,9,10,11,12,13,14 -s "alias=Data1" -l "alias=Data1, raid=5, readpolicy=readahead, writepolicy=writeback, preferredctrlid=1"
# Build Data2 LUN
# RAID level: 5
# Physical Drives: 15,16,17,18,19,20,21,22,23,24
# Alias: Data2
# Controller Affinity: 2
array -a add -p 15,16,17,18,19,20,21,22,23,24 -s "alias=Data2" -l "alias=Data2, raid=5, readpolicy=readahead, writepolicy=writeback, preferredctrlid=2"
# Set up dedicated spares
# Physical Drives: 3, 4
# Type: dedicated spares, Revertible to meta, data1, data2
spare -a add -p 3 -d 0,1,2 -t d -r y
spare -a add -p 4 -d 0,1,2 -t d -r y
init -a start -l 0 -q 100
init -a start -l 1 -q 100
init -a start -l 2 -q 100
# END
#End Copy
For more information about options configured by this script, see Promise VTrak: Configuring for Optimal Performance (E5000 Series)
