This article contains a script used to configure Promise VTrak RAID Controllers and SAS-connected Expansion Chassis: Xsan (Metadata and Data) configuration script - E5600f + J5600s
#Begin Copy
# Promise VTrak E5600f + J5600s Configuration Script
# Script Name: RAID Controllers and 1 SAS-connected Expansion Chassis: Xsan (Metadata and Data)
# Script Details: builds 6 LUNs from 32 drives (head + 1 expansion units)
# Global controller settings
# ALUA: enabled [required]
# Delete any existing arrays
# Delete array 0 thru 5
#array -a del -d 0
#array -a del -d 1
#array -a del -d 2
#array -a del -d 3
#array -a del -d 4
#array -a del -d 5
# Build MDC LUN
# RAID level: 1
# Physical Drives: 1, 2
# Alias: MDC
# Controller Affinity: 1
# Build Data1 LUN
# RAID level: 5
# Physical Drives: 5, 6, 9, 10, 13, 14
# Alias: Data1
# Controller Affinity: 2
# Configuration options: Capacity all (default), 1MB stripe size,
array -a add -p 5,6,9,10,13,14 -s "alias=Data1" -l "alias=Data1, raid=5, stripe=1mb, readpolicy=readahead, writepolicy=writeback, preferredctrlid=2"
# Build Data2 LUN
# RAID level: 5
# Physical Drives: 7, 8, 11, 12, 15, 16
# Alias: Data2
array -a add -p 7,8,11,12,15,16 -s "alias=Data2" -l "alias=Data2, raid=5, stripe=1mb, readpolicy=readahead, writepolicy=writeback, preferredctrlid=1"
# Build Data3 LUN
# RAID level: 5
# Physical Drives: 17, 18, 21, 22, 25, 26
# Alias: Data3
array -a add -p 17,18,21,22,25,26 -s "alias=Data3" -l "alias=Data3, raid=5, stripe=1mb, readpolicy=readahead, writepolicy=writeback, preferredctrlid=2"
# Build Data4 LUN
# RAID level: 5
# Physical Drives: 19, 20, 23, 24, 27, 28
# Alias: Data4
array -a add -p 19,20,23,24,27,28 -s "alias=Data4" -l "alias=Data4, raid=5, stripe=1mb, readpolicy=readahead, writepolicy=writeback, preferredctrlid=1"
# Build Audio/Scratch1 LUN
# RAID level: 5
# Physical Drives: 29, 30, 31
# Alias: Scratch1
array -a add -p 29,30,31 -s "alias=Scratch1" -l "alias=Scratch1, raid=5, readpolicy=readahead, writepolicy=writeback, preferredctrlid=2"
# Set up global spares
# Physical Drives: 3, 4, 32
# Type: Global spares, Revertible
spare -a add -p 3 -t g -r y
spare -a add -p 4 -t g -r y
spare -a add -p 32 -t g -r y
init -a start -l 0 -q 100
init -a start -l 1 -q 100
init -a start -l 2 -q 100
init -a start -l 3 -q 100
init -a start -l 4 -q 100
init -a start -l 5 -q 100
# END
#End Copy
For more information about options configured by this script, see Promise VTrak: Configuring for Optimal Performance (E5000 Series)
