Introduction:
When attempting to mount a Pegasus32 volume on Windows, you may encounter issues due to the kernel DMA protection and DMA guard settings. These security features can prevent the drive from loading properly. In this article, we will guide you on how to disable kernel DMA protection and DMA guard, which will allow the Pegasus32 drive to load successfully.
Please note that disabling these security features involves modifying system settings and should be done with caution. We recommend following the steps carefully to avoid any unintended consequences.
Disabling Kernel DMA Protection and DMA Guard:
To disable kernel DMA protection and DMA guard on Windows, you can follow the steps outlined below:
1. Open your preferred web browser and navigate to the following link: https://learn.microsoft.com/en-us/windows-hardware/drivers/install/cm-prob-console-locked
2. On the Microsoft documentation page, you will find detailed information about the "CM_PROB_CONSOLE_LOCKED" problem and potential solutions.
3. Read through the documentation carefully to understand the implications and risks associated with disabling kernel DMA protection and DMA guard.
4. Follow the instructions provided on the Microsoft documentation page to disable kernel DMA protection and DMA guard. The exact steps may vary depending on your version of Windows.
5. Once you have successfully disabled kernel DMA protection and DMA guard, restart your computer for the changes to take effect.
Mounting the Pegasus32 Volume:
After disabling kernel DMA protection and DMA guard, you should be able to mount the Pegasus32 volume on your Windows system .
Conclusion:
Disabling kernel DMA protection and DMA guard can help resolve issues when attempting to mount a Pegasus32 volume on Windows. However, it is important to understand the potential risks associated with disabling these security features. We recommend following the instructions provided by Microsoft in the linked documentation and exercising caution while modifying system settings. Once disabled, you should be able to successfully mount the Pegasus32 volume on your Windows system and access its contents in File Explorer.Remember to re-enable kernel DMA protection and DMA guard after you have finished working with the Pegasus32 drive to ensure the security of your system.
