Pegasus2 Power Consumption and Thermal Output values below are for Pegasus2 units with included factory installed hard disk drives.
| Pegasus2 R8 | ||||
| Status | Input Voltage | Current (A) | Power Consumption (W) | Thermal Output (BTU/Hour) |
| Idle | 110v/60Hz | 0.664 | 71.5 | 244.0 |
| 230v/50Hz | 0.385 | 69.8 | 238.2 | |
| Operation | 110v/60Hz | 0.745 | 80.3 | 274.1 |
| 230v/50Hz | 0.426 | 78.8 | 269.0 | |
| Pegasus2 R6 | ||||
| Idle | 110v/60Hz | 0.519 | 55.4 | 189.1 |
| 230v/50Hz | 0.321 | 54.6 | 186.3 | |
| Operation | 110v/60Hz | 0.608 | 65.5 | 224.7 |
| 230v/50Hz | 0.356 | 62.2 | 212.3 | |
| Pegasus2 R4 | ||||
| Idle | 110v/60Hz | 0.374 | 38.7 | 132.1 |
| 230v/50Hz | 0.256 | 38.3 | 130.8 | |
| Operation | 110v/60Hz | 0.483 | 45.5 | 155.3 |
| 230v/50Hz | 0.326 | 45.9 | 156.7 | |
| Pegasus2 R2+ with CF/SD Reader Pod | ||||
| Idle | 110v/60Hz | 0.251 | 24.2 | 82.6 |
| 230v/50Hz | 0.129 | 24.3 | 82.9 | |
| Operation | 110v/60Hz | 0.255 | 27.2 | 92.9 |
| 230v/50Hz | 0.142 | 27.3 | 93.2 | |
| Pegasus2 M4 | ||||
| Spin down | 110v/60Hz | 0.180 | 18.8 | 64.2 |
| 230v/50Hz | 0.107 | 19.0 | 64.9 | |
| Idle | 110v/60Hz | 0.190 | 19.9 | 67.9 |
| 230v/50Hz | 0.111 | 20.2 | 68.9 | |
| Operation | 110v/60Hz | 0.265 | 27.8 | 94.9 |
| 230v/50Hz | 0.147 | 29.0 | 99.0 | |
