This procedure can be used to restore the NS4600 after bad flash or downgrade firmware on the NS4600 to earlier build. Downgrades should “ONLY” be done if necessary (such as restoring a feature that is currently inoperable).
NOTE: Do not interrupt the Firmware update process. Doing so can result in permanent damage to the unit which will require an RMA replacement.
/* Font Definitions /
@font-face
{font-family:"Cambria Math";
panose-1:2 4 5 3 5 4 6 3 2 4;
mso-font-charset:0;
mso-generic-font-family:roman;
mso-font-pitch:variable;
mso-font-signature:-1610611985 1107304683 0 0 159 0;}
@font-face
{font-family:Calibri;
panose-1:2 15 5 2 2 2 4 3 2 4;
mso-font-charset:0;
mso-generic-font-family:swiss;
mso-font-signature:-1610611985 1073750139 0 0 159 0;}
@font-face
{font-family:Verdana;
panose-1:2 11 6 4 3 5 4 4 2 4;
mso-font-charset:0;
mso-font-signature:536871559 0 0 0 415 0;}
/ Style Definitions /
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-unhide:no;
mso-style-qformat:yes;
mso-style-parent:"";
margin-top:0in;
margin-right:0in;
margin-bottom:10.0pt;
margin-left:0in;
line-height:115%;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Arial","sans-serif";
mso-fareast-font-family:Calibri;
font-weight:bold;
mso-bidi-font-weight:normal;}
a:link, span.MsoHyperlink
{mso-style-noshow:yes;
mso-style-priority:99;
color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
color:purple;
mso-themecolor:followedhyperlink;
p.MsoListParagraph, li.MsoListParagraph, div.MsoListParagraph
{mso-style-priority:34;
margin-top:0in;
margin-right:0in;
margin-bottom:0in;
margin-left:.5in;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman","serif";
mso-fareast-font-family:Calibri;}
.MsoChpDefault
{mso-style-type:export-only;
mso-default-props:yes;
font-size:10.0pt;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.0in 1.0in 1.0in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
/ List Definitions */
@list l0
{mso-list-id:870267206;
mso-list-type:hybrid;
mso-list-template-ids:-1919531244 67698703 67698713 67698715 67698703 67698713 67698715 67698703 67698713 67698715;}
@list l0:level1
{mso-level-tab-stop:none;
mso-level-number-position:left;
text-indent:-.25in;}
@list l0:level2
{mso-level-tab-stop:1.0in;
@list l0:level3
{mso-level-tab-stop:1.5in;
@list l0:level4
{mso-level-tab-stop:2.0in;
@list l0:level5
{mso-level-tab-stop:2.5in;
@list l0:level6
{mso-level-tab-stop:3.0in;
@list l0:level7
{mso-level-tab-stop:3.5in;
@list l0:level8
{mso-level-tab-stop:4.0in;
@list l0:level9
{mso-level-tab-stop:4.5in;
ol
{margin-bottom:0in;}
ul
