Introduction:
The noise level of a storage solution is an important consideration for many users, especially those working in noise-sensitive environments or requiring a quiet workspace. This knowledge base article provides information about the noise levels of Promise Technology's PegasusPro R8 and PegasusPro R16 storage solutions, helping users understand and evaluate the acoustic characteristics of these products.
  1. PegasusPro R8 Noise Level:
    • The PegasusPro R8 is designed to deliver high-performance storage capabilities with minimal noise disruption.
    • The noise level of the PegasusPro R8 is approximately 37 dBA.
    • With this noise level, the PegasusPro R8 operates quietly, making it suitable for various environments, including home offices, creative studios, and small business settings.
  2. PegasusPro R16 Noise Level:
    • The PegasusPro R16 offers expanded storage capacity while maintaining a reasonable noise level.
    • The noise level of the PegasusPro R16 is approximately 39 dBA.
    • Although slightly higher than the PegasusPro R8, the noise level of the PegasusPro R16 remains within a comfortable range for most users.
    • Similar to the PegasusPro R8, the PegasusPro R16 is suitable for use in home offices, creative studios, and small to medium-sized businesses.
  3. Noise Level Considerations:
    • The noise levels mentioned for both the PegasusPro R8 and PegasusPro R16 are approximate values. Actual noise levels may vary slightly depending on factors such as system configuration, ambient noise, and operational conditions.
    • It's important to note that while Promise Technology has designed these storage solutions to operate as quietly as possible, some noise generation is inherent due to the mechanical components, including cooling fans and hard drives.
    • Users should consider the noise level specifications alongside their specific requirements and the environment in which the storage solution will be deployed. Noise-sensitive environments, such as audio recording studios or quiet office spaces, may necessitate additional soundproofing or alternative placement options.
  4. Noise Mitigation:
    • To minimize the impact of the noise generated by the PegasusPro R8 or PegasusPro R16, users can consider implementing the following strategies:
      • Position the storage solution in an area that reduces noise propagation, such as a dedicated server room, storage closet, or under a desk.
      • Utilize soundproofing materials or enclosures to dampen noise levels further.
      • Ensure proper ventilation and airflow around the storage system to maintain optimal operating conditions without compromising cooling efficiency.
Conclusion:
The noise levels of the PegasusPro R8 and PegasusPro R16 storage solutions from Promise Technology have been engineered to provide a balance between high-performance storage capabilities and minimal noise disruption. With noise levels of approximately 37 dBA and 39 dBA, respectively, these storage solutions offer quiet operation suitable for home offices, creative studios, and small to medium-sized businesses. Users should consider their specific requirements and the environment in which the storage solution will be deployed when evaluating the noise characteristics and exploring additional noise mitigation options if necessary.
