- Open vCenter Sever and select the appropriate HBA as indicated below:
- Select a LUN as indicated above by right click on it and select "Manage Paths" as indicated below.
- Then select which prefered path the to set this LUN to (storage controller 1 or storage controller 2) Note: Make sure that the LUN policy is set to "Fixed (VMware)" as indicated below.
CLI output of Logdrv -v before making changes:
LdId: 66
ArrayId: 4 SYNCed: Yes
OperationalStatus: OK
Alias:
SerialNo: 495345200000000000000000E2BE857E74045600
WWN: 22b3-0001-55f2-763b PreferredCtrlId: 1
RAIDLevel: RAID0 StripeSize: 64 KB
Capacity: 249.49 GB PhysicalCapacity: 249.49 GB
ReadPolicy: ReadAhead WritePolicy: WriteBack
CurrentWritePolicy: WriteThru
NumOfUsedPD: 1 NumOfAxles: 1
SectorSize: 512 Bytes RAID5&6Algorithm: N/A
TolerableNumOfDeadDrivesPerAxle: 0 ParityPace: N/A
Raid6Scheme: N/A
HostAccessibility: Normal
ALUAAccessStateForCtrl1: Active/optimized
ALUAAccessStateForCtrl2: Standby
AssociationState: no association on this logical drive
StorageServiceStatus: no storage service running
LdId: 67
Alias:
SerialNo: 4953452000000000000000000A987EF44E93A434
WWN: 2284-0001-55f3-b451 PreferredCtrlId: 2
Raid6Scheme: N/A
CLI output of Logdrv -v after balancing the LUNs:
LdId: 66
Alias:
Raid6Scheme: N/A
ALUAAccessStateForCtrl1: Standby
ALUAAccessStateForCtrl2: Active/optimized
LdId: 67
Alias:
Raid6Scheme: N/A
