Introduction
As times slowly passes it leaves it's mark on the world. The mountains rise up and wear down, the continents shift and change configuration, and worst of all, the dinosaurs have become extinct.
But on shorter timescales we also grow older, as does our equipment. Most things we use, like cars, furniture and most of all, computers either fail or become obselete. Few today use a computer based upon the venerable i486.
Storage has also changed over the years, in capacity, speed, and price.
Updating our equipment is an ongoing process. There are many reasons for updating our equipment, it could be because of equipment failures, or it could be that the storage speed of yesterday's equipment may not be up to the today's task of editing a 4k video.
Moving from a Legacy Pegasus to a Pegasus32 chassis
The promise Pegasus has a builtin capacity for upgrading. The disk set from a Pegasus1, a Pregasus2, or a Pegasus3 can be moved to a Pegasus32 chassis and the Volume will mount.
The process is simple...
  1. Make sure both Pegasus units are powered off.
  2. Move the Hard Drive carriers from the Legacy Pegasus to the Pegasus32. It's best to move the Legacy Pegasus drives to the corresponding slot on the Pegasus32.
  3. Connect the Pegasus32 power cable and Thunderbolt cable.
  4. After the Pegasus32 boots, the Volume should mount.
Some Limitations
The macOS version must support the Pegasus32 driver. macOS High Sierra for example, does not support the Pegasus32 driver. The Pegasus32 FCS (First Customer Shipment) driver supports macOS 10.14 (Mohave), 10.15 (Catalina) and above on Intel Macs.
If the Mac being used has Thunderbolt 2 ports, then a Thunderbolt 2 > Thunderbolt 3 adapter will be needed. The Apple adapter is recommended.
