To prevent overheating and ensure optimal performance of the Pegasus R12, it's essential to maintain proper ventilation around the device.
Key Guidelines:
- Clear Ventilation: Ensure that the air intake (top) and exhaust vents (bottom) are unobstructed, as blocking airflow may cause the system to overheat.
- Fan Functionality: The cooling fans pull cool air in through the top of the enclosure and expel heated air through the bottom. Keeping these areas clear allows the fans to regulate internal temperatures effectively.
- Secure HDDs and Top Cover: Confirm that all HDDs are properly seated and that the top cover is securely in place to maintain both airflow efficiency and protection of internal components.
Following these steps helps to prevent potential thermal issues, extending the lifespan and reliability of your Pegasus R12.
