Product: SATA150 TX2 Plus
Product Description: HBA
Platform: all
Firmware/Bios Version: all
Additional Description: This error is due to a protection problem in the Windows registry and can occur with a variety of drivers (sound cards and SCSI drivers have been reported).
To fix this problem :
Go to Start, Run... and type "REGEDT32.EXE" without the quotes to run the Registry Editor.
Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI and you will see a number of keys of the form "VEN_xxxx", where xxxx are strings like "1102&DEV_0004&SUBSYS_00011103&REV_04". Under each of these folders will be another folder with a long numerical name.
Open each folder and look for the "DeviceDesc" which matches the hardware you are trying to install. Highlight the key "VEN_xxxx" for that device and select 'Security'-'Permissions' from the top menu and then check "Full Control" and click OK.
Close REGEDT32 and then continue with the installation of your device.
