How to rebuild a Logical Drive with a new (unconfigured) disk manually
When a physical drive with adequate capacity has been replaced, the logical drive begins rebuilding automatically or manually in order to restore redundancy (fault tolerance).It will still function during logical drive rebuilding and your data is available.
[1].Double click this icon of WebPAM ProE at desktop
[2].Login with administrator account and password (default is password)
[3].You might encounter security warning and Select "Continue to this website" or "Go on to the webpage"
[4.] Go to localhost and follow these procedures
[5] Select a new inserted disk (Target Physical Drive) to rebuild
[Rebuild task is in the progress]
[Go to Logical drives and check the Logical drive status]:: Rebuilding
[Rebuild task is done]
