Option 1: Attaching additional J-Class with unconfigured hard disk drives currently installed.
- Be sure the new J-Class system is powered off.
- Temporarily unlatch all disks installed in the JClass chassis.
- Connect the SAS cables from the JClass chassis to the currently powered on and running E-Class or last J-Class in the chain. The connection go from Circle on the last device in the running enclosures to the Diamond input SAS connection on the new J-Class chassis.
- Power on the newly installed J-Class chassis.
- Once the new J-Class is up and running, verify that the E-Class can see the newly attached chassis by checking in WebPam or CLI. If the chassis is not detected, please contact Promise Technical Support for assistance.
- If the enclosure is seen, now it is safe to hot plug the unconfigured drives into the JClass chassis.
- Once all disks are detected, you will be able to create arrays and logical drives as needed.
Option 2: Removing a running J-Class with an arrays already configured and moving from one subsystem to another.
- Before shutting down and detaching the running J-Class, log into WebPAM or CLI and put the array into a 'Transit' state.
- Once the array is in Transit state, unlatch the disks from the chassis to be removed. Note this chassis must be the last chassis in the SAS cable chain.
- After unlatching the drives, power off the VTrak and detach the SAS cables.
At this point the JClass can be removed and/or moved to another E-Class or E/J-Class combination
- Once the additional J-Class is up and running, verify that the E-Class can see the newly attached chassis by checking in WebPam or CLI. If the chassis is not detected, please contact Promise Technical Support for assistance.
- If the enclosure is seen, now it is safe to hot plug the drives that are in Transit mode into the JClass chassis.
- Once all drives are installed, the array will come out of Transit mode and be put online so the array and logical drives can be seen.
