Product:VTrak 15200
Product Description: VTrak 15100/15200
Platform: Independant
Firmware/Bios Version: Any
Additional Description:
VTrak can only use static IP addresses for the Management Port. The default
Management Port IP address is 10.0.0.2. To change this IP address, do the
following:
1. From the Main Menu, press 4 and Enter to access Network Management.
The Network Management menu displays with the factory default settings shown above it.
Management Port IP Address: 10.0.0.2
Subnet Mask: 255.0.0.0
Gateway IP Address: 0.0.0.0
Telnet: disabled
TFTP Server IP Address: 0.0.0.0
SNMP Name: Sonoma
SNMP Location: Promise
Network Management
1. Management Port
2. Telnet
3. TFTP Server
4. SNMP
5. Ping
R. Return to Previous Menu
Please enter your menu choice>1
2. Press 1 and Enter to access the Management Port settings.
Management Port
1. Management Port IP
2. Subnet Mask
3. Gateway
3. Press 1 and Enter to select Management Port IP.
--------Configure Management Port IP address--------
Current management port IP Address: 10.0.0.2
Modify management port IP address(y/n)?>y
New management port IP address>192.168.1.56 (an example only)
New management port IP address: 192.168.1.56
Press Enter key to return
4. Press Y and Enter to modify the management port IP address.
5. Type the new IP address and press Enter.
VTrak confirms the new address.
6. Press Enter to return to the Network Management menu.
