To enable Time Machine functionality with Apollo Cloud, you must first make sure the device firmware is 0.01.0000.92 or above AND your Mac Apollo Cloud App is software version 1.1.1.0 or above.
- Your Apollo Cloud should be automatically detected by Time Machine. Please select your device under Available Disks.
- You will then be prompted for a username and password. If you are the owner of the Apollo, your username will be "Admin". If you are a member of the Apollo, you can determine your username by selecting "Time Machine Status" from the Apollo drop-down menu:
3. Enter the same password you use to log into the Apollo and Time Machine will automatically mount the share
