Start PromiseUtil to enable the Pegasus CLI.
- Open a Terminal window on your Mac.
- In the Mac Terminal window, type promiseutil to start the Pegasus Command Line Interface.
- You will see a list of each Pegasus attached, and be given a cliib> prompt.
To disable Pegasus Power Management functions.
- At the cliib> prompt type: ctrl -a mod -s "powermanagement=disable"
To enable Pegasus Power Management functions.
- At the cliib> prompt type: ctrl -a mod -s "powermanagement=enable"
To view Pegasus Power Management status.
- At the cliib> prompt type: ctrl -v
- You will see in the settings: PowerManagement: Enable ( or Disable)
