Sometimes in the manual or in other Knowledge Base articles, you will be asked to access the Command Line Interface, also known as the CLI.
In Windows, this is accessed by the Command Prompt (cmd).
It is an executable file called cliib in the apache directory of your Pegasus Utility. Once you change to that directory, run the command cliib.
1. The cliib executable file is located in C:\Program Files (x86)\Promise\Pegasus Utility\apache
2. Open Command Prompt and navigate to:
C:\Program Files (x86)\Promise\Pegasus Utility\apache>cliib.exe
3. Hit Enter/Return on your keyboard to enter the cliib.
