The Save Configuration feature was introduced on M-Class and E-Class series units. Please note that if the password field is changed and the left blank you will see the following error message (see attached JPEG). This will be addressed in the upcoming release for MX10 and EX10 series. We strongly recommend not to leave the password field blank (for security reasons)
This feature is also available from CLI. To retrieve the configuration information you can issue the following command from CLI (example):
export -t subsystem -f subsysteminfo.txt -s 192.168.7.100
Note: CLI requires that you use TFTP. A TFTP server will be necessary
