1. Open Settings > System Preferences > Sharing
  2. Make sure the service File Sharing is enabled ✔.
  1. Click the + to open sub-Finder window and select your Pegasus volume that you would like to reshare.
    Then click Add.
    (Adding Pegasus Volume "Pegasus R32 R4")
  1. You have now added your Pegasus volume as a Network Share with SMB. Select user permissions...
  1. And now the file share is ready.
Users can access the Pegasus Volume by going to the Finder menu, click Go and then click Connect to Server
