8.1 Check ATS-only command list
The problem arises when mounting the VMware datastore while the D5000/R3000 VAAI is enabled, as it results in the datastore being marked as ATS-only. Consequently, disabling the D5000/R3000 VAAI at this stage leads to the VMware datastore being flagged as abnormal.Follow the steps below to avoid this exception.
8.1.1 Check the volume or datastore ATS status:
vmkfstools -Ph -v1 /vmfs/volumes/VMFS-volume-name(Datastore name)
8.1.2. Change the ATS status:
vmkfstools --configATSOnly 0 device path(Volume name)
vmkfstools --configATSOnly 1 device path(Volume name
8.2. Example
The following steps demonstrate the change of VMware ATS-only flag for several cases.
A. Mount VMware datastore while D5K/R3K VAAI disabled.
- ATS-only flag will not be enabled for the datastore in such condition.
B. Mount VMware datastore while D5K/R3K VAAI enabled.
- ATS-only flag will be enabled for the datastore in such condition.
C. Disable D5K/R3K VAAI while VMware datastore is mounted.
- Datastore with ATS-only flag enabled will become abnormal.
D. Disable ATS-only flag before disable VAAI support in D5K/R3K
- Make sure the ATS-only flag is not enabled before disable VAAI support in D5K/R3K, so the datastore can be normal.
8.2.1 Mount VMware datastore while D5K/R3K VAAI disabled.
A. Mount 4*VMware datastores while D5K/R3K VAAI disabled.
Refer “8.2.1.a” as below.
- 4*VMware datastores not support VAAI, VMware field “Hardware Acceleration” is unknown.
- The 4 datastores named “p1v1_vaai_d_std”,”p1v2_vaai_d_std”,”p2v1_vaai_d_adv” and “p2v2_vaai_d_adv”.
[Figure 8.2.1.a]
B. ATS-only flag will not be enabled for these 4 datastores.
Refer “8.2.1.b” as below.
- In ESXi CLI excute “vmkfstools –Ph –v1 /vmfs/volumes/p1v1_vaai_d_std”
- The field “Mode” value is “public”, it’s means no “ATS-only” enabled.
[Figure 8.2.1.b]
8.2.2 . Mount VMware datastore while D5K/R3K VAAI enabled.
A. Mount VMware datastore while D5K/R3K VAAI enabled. Refer “8.2.2.a” as below.
- The old 4 VMware datastores support VAAI, VMware field “Hardware Acceleration” is supported.
- The old 4 VMware datastores named “p1v1_vaai_d_std”,”p1v2_vaai_d_std”, ”p2v1_vaai_d_adv” and “p2v2_vaai_d_adv”.
- The new 4 VMware datastores support VAAI, VMware field “Hardware Acceleration” is supported.
- The new 4 VMware datastores named “p1v1_vaai_e_std”,”p1v2_vaai_e_std”,”p2v1_vaai_e_adv” and “p2v2_vaai_e_adv”.
[Figure 8.2.2.a]
b.Check ATS-only flag for the 4 old datastores, the datastores created before VAAI enable.Refer “8.2.2.b” as below.
- The field “Mode” value is “public”, it means no “ATS-only” enabled.
[Figure 8.2.2.b]
C. ATS-only flag will be enabled for the new 4 datastores created after VAAI enable. Refer to “8.2.2.C” as below.
- In ESXi CLI excute “vmkfstools –Ph –v1 /vmfs/volumes/p1v1_vaai_e_std”
- The field “Mode” value is “public ATS-only”, it means “ATS-only” enabled.
[Figure 8.2.2.C]
8.2.3. Disable D5K/R3K VAAI while VMware datastore is mounted
In 8.2.1 and 8.2.2, we created 8 datastore.
4 datastores are created before the VAAI enabled and the other 4 are after VAAI enabled.
We disable the VAAI function in D5K/R3K and get the following result. Refer to “8.2.3.a” as below.
A. Disable VAAI function on D5K/R5K.
B. 4 datastores created when VAAI disabled, is good
- “p1v1_vaai_d_std”,”p1v2_vaai_d_std”,”p2v1_vaai_d_adv” and “p2v2_vaai_d_adv”.
C. 4 datastores created when VAAI enabled, might be fail, miss, or inaccessible.
- “p1v1_vaai_e_std”,”p1v2_vaai_e_std”,”p2v1_vaai_e_adv” and “p2v2_vaai_e_adv”.
D. “ATS-only” flag of VMware datstore will be affected when storage’s VAAI enable/disable.
[Figure 8.2.3.a]
We can use VMware tools “vmfstool” to check datastore status and disable the ATS-only flag.
E. Use VMware “vmfstool” to check datastore ATS-only will fail. Refer “8.2.3.e” as below.
- The 4 failed datastore cannot be manipulated and “vmkfstools” show the error message.
[Figure 8.2.3.e]
F. Use VMware “vmfstool” to remove datastore ATS-only flag will fail. Refer “8.2.3.f” as below.
- In ESXi CLI excute “vmkfstools –configATSOnly 0 eui.22980001552754a2
[Figure 8.2.3.f]
G. Disable ATS-only flag before disable VAAI support in D5K/R3K
We must disable datastore ATS-only flag before disable VAAI in D5K/R3K.
Refer “8.2.3.g” as below.
- In ESXi CLI execute “vmkfstools –configATSOnly 0 eui.22980001552754a2
Refer “8.2.3.h” as below.
- In ESXi CLI execute “vmkfstools –Ph –v1 /vmfs/volumes/p1v1_vaai_e_std”
[Figure 8.2.3.g]
[Figure 8.2.3.h]
H. Disable VAAI support in D5K/R3K.
I. Check VAAI status in VMware ESXI/VCenter.
Refer “8.2.3.i” as below.
