How to Save a Service Report from the Pegasus32 Series using Promise Utility
Prior to calling Promise Technical Support for any Pegasus32 related issues, please capture and prepare the Service Report:
- Open the Promise Utility,click on Subsystem Information, then unlock the padlock, and then click Save Service Report.
- If this is successful, then it will open a new window for you to choose a folder to save the report. After that, you may use Finder to see that the file has been created in the folder.
If a Service Report can't be saved for some reason, this is the manual method.
- Open the Mac OS Terminal session: In Finder, go to Applications, then open Utilities, then open Terminal.
- At the "$" prompt, type
promiseutil
and press Enter. If Promise Utility Pro is installed, this command will change the prompt to
cliib>
At the cliib> prompt, type each of the following commands on their own line, pressing Enter after each one:
subsys -v
enclosure -v
ctrl -v
phydrv
phydrv -v
array -v
logdrv -v
checktable -l 0
event
event -l nvram
Once that is done, then in the Applications folder, open TextEdit, and from File select New Document.
Select All from the Terminal window and Copy the entire terminal session to your clipboard; then, Paste it into the TextEdit document. Finally, Save the TextEdit document as a "Rich Text File" with the name servicereport.
These logs are vital in assisting Technical Support for resolution of any issues.
This links to a Promise KB article on how to attach files to a web support case:
http://kb.promise.com/thread/how-to-attach-files-to-your-web-case/
