Product macOS 10.13/10.14 Support Driver Version Utility Kernel Extension Notes
SANLink1 – FC (4Gb) N/A Managed in System Preferences > Fibre Channel N/A – The chipset built into the SANLink1 is the same LSI PCI card used in the older generation Mac Pro SKUs.  No driver is required as the kernel extension is built into macOS.
SANLink2 – FC (8Gb/16Gb) 2.0.9 1.04.0000.11 SANLink-FC.kext (com.promise.SANLink-FC)  Driver required from Promise. You must also approve the kernel extension for macOS 10.13 & 10.14.
SANLink2 10Gb BASE-T /SFP+ 1.8.2 1.04.0000.11 SANLink2-10GE.kext (com.promise.driver.SANLink2-10GE)  Driver required from Promise. You must also approve the kernel extension for macOS 10.13 & 10.14.
SANLink3 F2 (16Gb) 2.0.9 1.04.0000.11 SANLink-FC.kext (com.promise.SANLink-FC) Driver required from Promise. You must also approve the kernel extension for macOS 10.13 & 10.14.
SANLink3 T1 NBASE-T 1.52.2 Managed in System Preferences > Network SL3T1.kext (com.promise.driver.sl3t1) Driver required from Promise. You must also approve the kernel extension for macOS 10.13 & 10.14.
SANLink3 N1  N/A Managed in System Preferences > Network  N/A – The chipset built into the SANLink3 N1 is the same Aquantia chip used in the iMac Pro.    No driver is required as the kernel extension is built into macOS.
