Product: Vtrak 15100
Platform: Independant
Firmware/Bios Version: Any
Problem Description: Compatability List for Hard Disk Drives
Additional Description:
The following products have been tested by Promise and verified to be compatible with the VTrak subsystem. Products not on this list may or may not be compatible with VTrak.
Hard Disk Drive Compatibility:
Drive Vendor |
Drive Family |
Drive Model |
Capacity |
Spindle |
Buffer |
Interface |
Samsung |
SpinPoint P80 |
SP1614C |
160GB |
7200RPM |
8MB |
SATA150 |
Samsung |
SpinPoint P80 |
SP1213C |
120GB |
7200RPM |
8MB |
SATA150 |
Samsung |
SpinPoint P80 |
SP0812C |
80GB |
7200RPM |
8MB |
SATA150 |
Seagate |
Barracuda7200.7 Plus |
ST3200822A |
200GB |
7200RPM |
8MB |
ATA100 |
Seagate |
Barracuda7200.7 SATA |
ST3160023AS |
160GB |
7200RPM |
8MB |
SATA150 |
Seagate |
Barracuda7200.7 |
ST3160021A |
160GB |
7200RPM |
8MB |
SATA150 |
Seagate |
ST3120026AS |
120GB |
7200RPM |
8MB |
SATA150 |
Seagate |
ST380013AS |
80GB |
7200RPM |
8MB |
SATA150 |
Seagate |
Barracuda7200.7 |
ST380011A |
80GB |
7200RPM |
2MB |
ATA100 |
Seagate |
BarracudaSerial ATA V |
ST3120023AS |
120GB |
7200RPM |
8MB |
SATA150 |
Seagate |
Barracuda ATAV |
ST3120024A |
120GB |
7200RPM |
2MB |
ATA100 |
Seagate |
ST380023AS |
80GB |
7200RPM |
8MB |
SATA150 |
WesternDigital |
Raptor |
WD360GD |
36GB |
10,000RPM |
8MB |
SATA150 |
WesternDigital |
Raptor |
WD740GD |
74GB |
10,000RPM |
8MB |
SATA150 |
WesternDigital |
Raptor - TCQ Enabled |
WD740GB |
74GB |
10,000RPM |
8MB |
SATA150 |
WesternDigital |
Caviar SE |
WD2500JD |
250GB |
7200RPM |
8MB |
SATA150 |
WesternDigital |
Caviar |
WD2500JB |
250GB |
7200RPM |
8MB |
ATA100 |
WesternDigital |
Caviar SE |
WD1200JD |
120GB |
7200RPM |
8MB |
SATA150 |
WesternDigital |
Caviar |
WD1200JB |
120GB |
7200RPM |
8MB |
ATA100 |
Maxtor |
MaXLine II |
5A300J0 |
320GB |
5400RPM |
2MB |
ATA133 |
Maxtor |
MaXLine Plus II |
7Y250M0 |
250GB |
7200RPM |
8MB |
SATA150 |
Maxtor |
MaXLine Plus II |
7Y250P0 |
250GB |
7200RPM |
8MB |
ATA133 |
Maxtor |
DiamondMaxPlus 9 |
6Y200M0 |
200GB |
7200RPM |
8MB |
SATA150 |
Maxtor |
DiamondMaxPlus 9 |
6Y200P0 |
200GB |
7200RPM |
8MB |
ATA133 |
Maxtor |
DiamondMaxPlus 9 |
6Y080M0 |
80GB |
7200RPM |
8MB |
SATA150 |
Maxtor |
DiamondMaxPlus 9 |
6Y060M0 |
60GB |
7200RPM |
8MB |
SATA150 |
Hitachi |
Deskstar 7k400 |
HDS724040KLSA80 |
400GB |
7200RPM |
8MB |
SATA150 |
Hitachi /IBM |
Deskstar 7K250 |
HDS722525VLSA80 |
250GB |
7200RPM |
8MB |
SATA150 |
Hitachi /IBM |
Deskstar 7K250 |
HDS722512VLSA80 |
120GB |
7200RPM |
8MB |
SATA150 |
Hitachi /IBM |
Deskstar 7K250 |
HDS722580VLSA80 |
80GB |
7200RPM |
8MB |
SATA150 |
Hitachi /IBM |
Deskstar180GXP |
IC35L180AVV207 |
185GB |
7200RPM |
8MB |
ATA100 |
Hitachi /IBM |
Deskstar120GXP |
IC35L120AVVA07 |
120GB |
7200RPM |
2MB |
ATA100 |
Fujitsu |
Pre-Released |
Pre-Released |
40GB |
4500RPM |
2MB |
SATA150 |
Additional Information: *ATA100/ATA133 drives use the optional Promise SATA-to-PATA adapter.
This is the list of current qualified and supported compatible products. If it is on this list then it has been tested and approved for use. If it is not on this list then it is not supported. It may or may not work but it is not supported
by Promise.
