Best Practices for Data Protection
This article describes Promise Technology’s recommended best practice procedures for optimal data protection.
Predictive Data Migration - PDM
PDM, one of the unique technologies in the Promise Perfect Raid suite, should always be enabled. PDM proactively detects possible drive failures before they could occur and migrates data to a new healthy drive. Predictive Data Migration dramatically reduces the potential for data loss as well as the likelihood of a logical drive (array) going critical. PDM requires a global spare or unconfigured drive within the array. If PDM cannot be implemented (no spare or unconfigured drives available), there’s another proactive mechanism that can be implemented: Medium Error Threshold settings.
Medium Error Threshold is a configurable value within the cli and WebPAM PROe. The value is the number of bad blocks tolerated before the controller marks the drive as dead. By default, the Medium Error Threshold is disabled. The value can be set from 0 to 4294967294. The threshold only functions when the array is in an OK or Degraded state. It will not function if the array is critical or if a non-redundant RAID type (Raid 0) is used.
- Medium Error Threshold configuration can be used in conjunction with PDM for even greater disk health monitoring.
Configuration
Configuration from the CLI:
- Log-in to the VTrak EClass via Telnet or the Serial console.
- When at the CLI prompt, type the following command to set the Medium Error Threshold to 64 bad blocks.
administrator@cli> phydrv -a mod -s "mediumerrorthreshold=64"
- To confirm the setting change, type the following command at the CLI prompt.
administrator@cli> phydrv -v -p 1
- The resulting command output will show info for physcial drive Pd Id 1.
PdId: 1
OperationalStatus: OK
Alias:
PhysicalCapacity: 698.64GB ConfigurableCapacity: 698.49GB
UsedCapacity: 0Byte BlockSize: 512Bytes
ConfigStatus: Global Spare Location: Encl1 Slot1
ModelNo: ATA Hitachi HUA72107 VisibleTo: All Controllers
SerialNo: GTA200P8G247SA FirmwareVersion: GK8OA70M
DriveInterface: SATA 3Gb/s Protocol: ATA/ATAPI-7
WriteCacheSupport: Yes WriteCache: Enabled
RLACacheSupport: Yes RLACache: Enabled
SMARTFeatureSetSupport: Yes
SMARTSelfTestSetSupport: Yes SMARTErrorLoggingSupport: Yes
CmdQueuingSupport: NCQ CmdQueuing: Enabled
CmdQueueDepth: 16 MultiDMASupport: MDMA2
MediumErrorThreshold: 64
UltraDMASupport: UDMA5 DMAMode: UDMA5
Errors: 0 NonRWErrors: 0
ReadErrors: 0 WriteErrors: 0
- You can verify that the Medium Error Threshold setting is now set to 64 bad blocks as shown above
Configuration from WebPAM PROe
- Log-in to WebPAM PROe.
- Click on Enclosures -> Enclosure 1 -> Physical Drives and then choose the Global Settings tab.
You will see a screen like the example below:
- Type in the number of bad blocks for Medium Error Threshold. You may adjust the settings for SATA or SAS drives independantly. For example, set the Medium Error Threshold to 64 bad blocks.
- Click the Submit button.
- When WebPAM PROe screen updates, click on the Global Settings tab again. This will display the change.
Please note - Independant from PDM and Medium Error Threshold, a physical drive will always be marked dead if 5 timeouts are experienced within a 30 minute period.
RelatedArticles:
“KB-10255 New Error Threshold Values for SR2.6”
http://kb.promise.com/thread/new-error-threshold-default-values-for-sr2-8
