Battery Reconditioning
Reconditioning the battery helps maintain battery fitness. The reconditioning process will completely discharge and then fully recharge the cache battery.
During reconditioning, if the Adaptive Writeback Cache function is enabled, the controller cache is set to Write Thru. After reconditioning, and if the battery hold time is greater than 72 hours, the cache is reset to Write Back.
By default, reconditioning the battery will happen on the 1st of every month at 2:00 AM. This time may not be the most convienent schedule for some installations.
Battery reconditioning can be scheduled for a more convienet time via WebPAM PROe.
Scheduling Battery Reconditioning
  1. Log-in to WebPAM PROe.
  2. In the left hand window, click on the Subsystem icon or IP address of the VTrak.
  1. Now click on the Scheduler tab in the right side window.
  2. Click on Battery Reconditioning from the activity list.
    • The scheduling menu will show.
  1. If Battery Reconditioning is not in the list, you will need to schedule this activity.
    • Click on the down arrow to the right of the Scheduler tab.
    • Select Add Battery Reconditioning Schedule from the drop down menu.
  1. Adjust the schedule to a convenient time.
    • This example below will recondition batteries on the first Saturday of every month at 2:00 AM.
    • You may also enable or disable the scheduled event by clicking the Enable This Schedule box.
  1. Once the schedule is configured, click Submit to save changes.
