Step 1: Connecting the power
Attach the AC adapter power cord to the power insert on the back of the device. Plug the other end of the adapter into a suitable power source.
You must use the AC power adapter shipped with the device. Using a different power adapter can damage the device or might present an electrical safety hazard.
Step 2: Connecting the network cable
Use the included Ethernet cable to connect to the network port on the back of the device. Connect the other end to a networking device that allows the Apollo to connect to the Internet, such as a broadband router, or office Ethernet LAN that is connected to the Internet.
The Apollo does not require configuration of network settings or any other settings for initial system setup. Just make sure it has an available path to the Internet.
