SYMPTOMS
When you try to move a physical disk resource from one cluster node to another cluster node on a Microsoft Windows Server 2003-based server cluster, the move operation is unsuccessful.
For more information, please see Microsoft Knowledge Base article 932465
Important The Microsoft KB article contains information about how to modify the registry. Make sure that you back up the registry before you modify it. Make sure that you know how to restore the registry if a problem occurs. For more information about how to back up, restore, and modify the registry, click the following article number to view the article in the Microsoft Knowledge Base:
256986 Description of the Microsoft Windows registry
